| I recently lost one of the metal paperclip like doobers that holds one of the electrical harness connectors to its device. In the process of trying to determine which doober I needed, I came across some incomplete info that I have completed in the case that it help anyone else. I wasn't able to find this information on the site or the web. Nissan calls these things "harness spring" or "spring harness". You might call them a clip or a fastener. I found a list of part numbers in this post of Bernie's from way back in 2003. As he suggested, I ordered all of them to figure out which was which. The part numbers (from Bernie's post): B4111-U7600 Spring Harness B4111-U7601 Harness Spring B4111-U7602 Harness Spring B4111-U7603 Spring Harness B4111-U7604 Spring Harness Here's an image of what each of these looks like along with their approximate inner length from side to side in mm.
I can confirm that B4111-U7602 is correct for the throttle position sensor on my 93 TT. Coz has at least 3 of these available and they can be found if you search for "B4111" at his site. The parts pictured above that I worked with were ordered from Courtesy Nissan in Richardson, TX. Anyway, maybe this is helpful to someone. Andy
